Stackers you say??
76nemo
Ogdensburg, NY
Are the use of these Stackers some of you guys use have specific regulations? I guess they are seen as supported, yet not secured. I thought of trying them in a new job coming up. I have never seen them in our supply house, nor have I ever heard of them before hearing of them here.
How deep can you go and how far in between do they have to be stapled? If they are considered "secured", I am floored again:rolleyes:
Any specific methods and regulations that go along with them? I can't find any. In this project, they would be out of physical harm.
I use them in leiu of staples when I do use them.
Actually, I don't use all that many. Coming down the stud at multi-gang switch boxes and at the panel to secure the home runs for recessed panels. Those are the main times. Maybe a dozen or so in a 2000 square foot new home.
i like using stackers when i go down studs. personally it looks better to me and theres less of a risk of a crazy sheetrocker missing and hitting my wire. plus its easier to remove wire if you change plans later instead of a pair of dikes and prying a staple
You're just now going to "TRY" them? Decent sized job and I'll kill 4-5 bags...
Like anything else - neatness counts IMO. Also derating (310.15) if you get too crazy.
Anyway I plan out the whole job and find a soffit or somewhere to run sets of them and take all of the HR's out on them. Run up both sides of a stud bay with a whole bunch...
Got a thing for "securing" - or an Inspector who does? Put a zip tie around it on them....:rolleyes:
I tried the zip tie technique, inspector called it bundling... :roll: So I just cut out every other one... he still wasn't too happy...
Zip tie technique?
Cable stackers--in my opinion-are the best way to go! Are you putting zip ties on the wires in the panel cabinet? This drives me nuts:mad: :cool: :smile:
Sure call it bundeling! Call it stacked , call it stacked and bundeled! Either apply and both in the same way - but not additive to each other. 310.15B2 applies only once..... :grin:
Is it supported? Secured? Stacked? Bundeled? Yeah! :grin:
Let me reitterate. Read my profile. The last thing I want is to be dealing with is the general public and residential work. I take side jobs and run my work cleaner if not OCD better than the next guy/woman. I don't have all the pic's you guys do. I mainly work on equipment, alot of times on board level. I am thinking of relocating and residential may be where I have to start.
Stackers? FR*G stackers, my work is done in pipe. If I choose to do the resi route, I would like to know where it stands. Is anyone here saying "Stackers" are considered "secured"???? I just need to know if they have limitations?????
We are required to use them especially into the panels and in multi ganged switch banks I use them sparingly. Other than that staplegun city no finger bangers for me.
I use them like a drunken sailer on shore leave. They are worth the money. Set looks aside the most important thing is the integrity of the work, is it installed in a manor that it will function to it's peak performance for many years. Stacker's hold the wire neatly and safely and they are easy to use. What more do you need.
resistance said:
Zip tie technique?
I was talking about a zip tie around a cable stacker.
LMAO I could think of another analogy or two equally fitting and just as inappropriate but concise - but why try to top that?!?! :grin: :grin:
76nemo, sorry i don't have you backround memorized but yes - to most stackers would be considered secured. (enough) And going into resi should not stear you away from pipe IMO - with a mix of both cable and pipe, resi and commercial are the same to me - I get along just fine depending on the circumstance....
If a factory guy is going to do anything besides fix machines in a factory, wiring a house should not be it. Wire houses for a little bit just to say you did it, and move on. You should get into service, which is where the talent is sorely lacking.
480sparky said:
If I have more than three cables coming down the stud, it gets a stacker. But I end up using only 8-10 per house.
I guess we're about the same in that regard. I think I'd have to have a major talk with a guy that used bags full on one house, unless there was some special reason. No compelling reason to make artwork out of what's getting covered up.
The only other time I'll use them is if the stud cavity I need to run down is far too thin for bangin' on a regular staple. I use stackers that have the nail at a 45? angle, so I can get them into tight places when I need to. Some places I have no other choice, so I 'burn' two or three just to keep moving.
I agree - when you don't have room to swing a hammer
between studs, stackers make things go a lot faster since
you're swinging from outside the wall.
3 types show up on our jobs - (1) red GB "Multicable Stables,
which GB says "secures NM/Romex", but really doesn't
hold the cable -- I usually only use these if I have a lot
of low-votage cables together. They are also the easiest
to add or subtract cables because there is a "snap" for
all four cable slots. (2) yellow Greenlee CA1 cable anchors
-- hold the cable the most securely, but are hardest to
get the cable in because the plastic is more rigid than
the other two and (3) pink 3M stack-it cable stackers which
are the original and hold the cable firmly enough, but
not as tight as the greenlee. If I have a choice I use
the GB for low-voltage because it holds the most LV
cables and is easiest to add/subtract and the Greenlee
for romex because it is most secure. Have used all three
on romex, and never had a problem. 10-20 per 2K sq ft
house is about what I use.
I like the home made stackers.
They keep the cable away from the studs and they are free.
