More than often we oversize emergency generators in our calculation, base specifically on the inrush current tripping the generator by turning all RTU's at he same time. A way of solving that problem I believe can be using a time delay relay on each HVAC, that way they won't start up all at the same time. This solution came after Value engineering the project.
now here is my question:
As the RTU's are starting up in sequence, how much should I consider the inrush current of that last RTU in the sequence? do I have to take in account the LRA of the unit for my sizing?
after a regular breaker is design to sustain that inrush current, I'm not sure the generator is design the same way.
Thanks
Thanks
