Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
Not that I care one way or the other but my issue would be more with the welded joints than stainless vs. mild steel for the simple reason that most stainless lengths of tubing are 10 or 20' long. if you weld the joint together, unless you run a camera inside the tubing to see how the weld turned out.... which I doubt they do..... I don't see how you'd ever really know how smooth the weld turned out on the inside.
JAP>
You inspect them by cutting out a random sample of finished welds and inspecting them. I saw this done in an elevator tower, and they were welds like I will never be able to make. A beauty to behold, and bent completely backwards, cut and polished, and not a flaw to be seen.
