Here's an idea where I would want some input. The price of infrared motion detecting light switches has come down enough that instead of putting in a bunch of 3-ways and 4-ways I can wire some motion switches in parallel with each other.
This is pretty straightforward for a hallway, walk-in closet, and so forth.
Has anybody tried this with stairway lighting? I might need to mount the motion sensing wall switches at funny angles but then I already know how to use a rafter square. I am thinking that the switch down near the bottom would need to be at a 45 degree angle or have a cutoff shutter so as to not sense past the bottom. There would also need to be a wall sensor 2/3 of the way up that is aligned with the stairway.
Or, mount a wall switch in the ceiling of the stairway and adjust the shutters to keep it from seeing much pasat the top or bottom.
Or, would 1 wall switch at the bottom, 1 at top, and 1 in the middle be better so that the manual override buttojn could be used.
I would also restrict the wall switches that are ON or AUTO for the override button - the ones with an off position would allow some body to push too many buttons.
