henry1971 said:Is there anywhere in the code that says you cannot wrap a stranded wire around a ground screw or device screw ?
Thank You
RECEPTACLES FOR PLUGS AND
ATTACHMENT PLUGS (RTRT)
GENERAL
This category covers general use receptacles for use in wiring systems
recognized by ANSI/NFPA 70, ??National Electrical Code?? (NEC), and outlets
for use in appliances and fixtures. It also covers some attachment
plugs, male inlets, and cord connectors with non-standard slot or blade
configurations which are part of a line of wiring devices including receptacles.
Other similar attachment plug devices are covered under Attachment
Plugs (AXGV).
TERMINALS
Terminals of the wire-binding screw, setscrew, or screw-actuated back
wired clamping types are suitable for use with both solid and stranded
building wires.
celtic said:Another way is to just use a sta-con![]()
chris kennedy said:Off topic: Are Sta-Cons approved to deliver or clear a fault current?
You may know them generically as "crimp terminals" of various sorts. Rings, spades, forks, Fast-on's, etc.e57 said:Maybe a terminology issue here - Whats a "Sta-con"?
mdshunk said:I find that jobs that utilize stranded wire also use backwired devices, which largely makes wrapping stranded conductors around a screw terminal unnecessary.
celtic said:No, but there is a "trick" to having the strands make up tight....twist the wires to the RIGHT, then stuck them under the screw as usual.
infinity said:I thought that we do the opposite of "normal twisting" and twist the strands to the left?
celtic said:I just spent the better part of today installing outlets way up in the ceiling with all stranded wires ...I kept telling myself "Summer is only temporary, Autumn will be here soon" :smile:
chris kennedy said:I'm sorry it was so hot in NJ today.:roll:
celtic said:Actually, it wasn't that bad outside(80 ish) ...but 20' up, in a ceiling, surrounded by all sorts of theater lighting ~ well, that changes things slightly :grin:
chris kennedy said:Hey, it appears I'm flying Pierre down for an inspection. Why don't I fly you in also so we can all stand in the hot a_ _ electric room and sweat all over his red tags?:grin:
Ah, I see.... Hate 'em, rarely use 'em...mdshunk said:You may know them generically as "crimp terminals" of various sorts. Rings, spades, forks, Fast-on's, etc.
e57 said:But to be clear, not all "back-wired" devices are rated for stranded. Stab-in devices could also be called back-wired, but are only rated 14 solid for the time being....
peter said:I haven't seen much difference whether the wire is twisted to the right or the left.
