No. Heats are in the shaft to detect HEAT as in a Fire in the elevator shaft means "Please do not use the elevator any longer". The heat detector isn't like a smoke that can be set off inadvertently by cigarettes, or by smoke only oven fires and from small fires or burning combustibles. With heat detectors (purchased for a pre-determined heat point i.e.185 degrees) only heat sets off the device and when used to signal the SHUNT TRIP it is meant to remove the power and car movement from a situation that's hidden in the shaft and getting worse by the second,
I believe the elevator is sent to the 1st floor so the 1st responders can use it. The heat detector is meant to SHUNT the power source if heat is detected in the shaft or elevator control room, so the firemen are not in the elevator while the fire is close to engulfing them. Heat detectors are a matter-of-Fact device meaning it takes a hot fire to initiate it and if its sensing that heat set point there is almost no doubt you have fire where you don't want people.
also, the device in the pump room is because hot oil mixed with flames equals more fire
