i have a generator stand by duty, i want to power up an area approx 1600 sq ft with power for lighting,rec, and 1 -5 ton hvac with gas heat, rec circuits only computers and miscellaneous 120v loads. load calc <40a per ph
35 kva, 480 3ph,
100 amp main brkr SDS, neutral is switched, ats asco.
i want to feed an 30 kva 3 ph xfmr with this genset.
any comments or suggestions on this amount of load for this size generator?
i am working with an ec on this project, and he has the bid at present, I want to learn as much as i possibly can, so i ask questions?
i would like to add that i have learned a great deal from you guys from doing searches on subjects and reading the threads.
you guys are ok in my book,
35 kva, 480 3ph,
