Standard Height of Emergency Light in Gym
Martin B
Nebraska
I don't think there is a "standard height". You need to maintain enough light for egress. There is a minimum number of lumens required by the building code but I don't remember what it is. Maybe like 1 Lumen?
kenman215
albany, ny
What is the recommended height off of the finished floor to an emergency light (power pack)?
I'm assuming that you're talking wall mount here? If so, my company mounts tem
at 80" to center AFF. Big thing you have to look at, though, is protection for the light since its in a gym. Make sure it's either impact rated or you have a cage that goes around it.
jonny1982
CA
Thankyoy
Sent from my E6782 using Tapatalk
GoldDigger
Placerville, CA, USA
Retired PV System Designer
The standard will call for a light level in lux or in foot-candles, not the output of the fixture in lumens.
rt66electric
Oklahoma
easy enough to repair with a 10 ft ladder , but difficult for inspector to push test
A height Accessible by a 10 ft ladder.
Unless you want service calls 5 years from now ,and "bring your lift"
