Josh111 the funny thing about the NEC is that its copyrighted (c) material owned by the NFPA. But then it becomes a public law, as it gets adopted by reference.
There results this odd tension around this.
An author like the NFPA gains ‘exclusive rights’ in their work "immediately upon the work’s creation” (quoting 17 U.S.C. § 106)).
It is only once a jurisdiction subsequently incorporates a privately authored standard (NEC) that government makes
any decisions vis-à-vis the already created and copyrighted expressive work.
At that point, though, the state should require, by law, the standard remove its copyright.
see
en.wikipedia.org
What interests me is the way the RFC standards (codes) that run the internet are in the public domain, and can't be copyrighted
RFC documents contain technical specifications and organizational notes for the Internet and are the core output of the IETF.
www.ietf.org
The 'internet' works just fine without a NFPA owning all the standards, so I see no value in the NFPA owning the current electrical code in 2021.
The thing to do would be make a copy of the last NEC that was not owned by the NFPA (1968?) and make a public domain electrical code panel to ammend it up to a modern standard , keep it in the public domain like the RFC internet standards and get a state to adopt it.
They way to do force this is to get your state legislature / governor to pass a bill banning codes that are not in the public domain and banning adopting standards by reference that are not in the public domain.
Cheers
