JDB3
- San Antonio, Texas
Any body know the requirement about a recess light in a "steam shower" ? My first time wiring a house with one.
I just install a wet location trim... thats it. IMO, its not required, unless subject to shower spray, but just makes sense. You would need a damp location trim otherwise....
Check out 410.4 (D)
If that can is located in the zone--8' then I bet most inspectors would turn down an open trim. Standard shower trim on a recessed can works fine.
I think one could easily argue the splash effect at 8'.Yep, they do, but without cause... because they are not reading what is written.
Thanks for the reply s. Some post bring up another question, in another house with 10 foot ceilings, recess light over the combination tub / shower, would an open trim & BR30 bulb meet code (the shower head in this application is @ 5 feet since it is in children's bath).
We could argue about anything, but I read nothing about splash effect in the code, only shower spray, so unless that spray is directed at the ceiling, I disagree.
Aiming for code minimum a lot huh?
