Mark Smith
Does anyone know if a 3/4 inch emt slip coupling are Manuf.? We have a project that off site pre-fab will require these once we get on site ( several 100 or more
Listing issues aside, I have seen them made in the field by grinding away the ridge on the inside of die cast fittings. Can't ever say that I've seen a steel slip fitting for EMT.
Depending on how the steel coupling is made it might be pretty easy to make one. Some steel couplings simply have a small indent for the stop, which could be ground away pretty easily.
Did the old indenter system couplings have a stop in them?
Whillis,
Found them, UL approved.
But at $53 each, I wonder if there is something else.
Several hiundred of these would be pricey.
I managed to scrounge up a few couplings with the dimple stop, but they all had more than one dimple. That would be a lot of filing.Yes. I had one of those couplings for a while.. but junked it since i dont have the indenter. It had an interior ring, not just a dimple.
~Matt
Do couplings even need to be listed?
What about a piece of flex and emt-to-flex conn as an alternative? That's what we use for expansion joints...
