Depending on the application, often we don’t see the neutral brought in beyond the service disconnect for a 480v system. For 120/208 — the neutral is usually alive and well clearly for the 120v loads.
If this were me, I would likely use 25kw 120/208 inverters, with a neutral, and an combiner panel. I don’t believe the larger SolarEdge is worth it, when you factor in the transformer. CHINT makes a nice 25kw as well as the new SMA.
If RSD is required with your project, then SolarEdge is a viable option. If it isn’t, then I wouldn’t use SolarEdge due to the optimizer requirement.
