racerdave3
- Western Massachusetts
I just completed the wiring for an above ground "Storable Swimming Pool". This pool is above ground with 42 inch side walls. I ran PVC underground to a location 6 feet away from the edge of the pool and installed a GFCI protected receptacle with switch that will control the pool pump. My question now regards grounding and or bonding of the pool. As I am reading it in the codebook, this pool installation is satisfied with what I have already done. I had originally intended on driving an 8 foot ground rod at the pool and at the very least come off of that and bond the pump as it has a lug right on the motor. So what are your thoughts on this? Am I done as it sits right now or is driving the rod and bonding required or preferable? Thanks.
