J Fimbianti
New member
- oak forest illinois usa
article 480.6 is "overcurrent protection for "Prime movers"
what is the definition of a "Prime mover"
Maybe I'm missing something but I don't see the words prime mover anywhere in 480.6.
480.6 Overcurrent Protection for Prime Movers. Overcurrent
protection shall not be required for conductors from a battery
with a voltage of 60 volts dc or less if the battery provides power
for starting, ignition, or control of prime movers. Section 300.3
shall not apply to these conductors.
Ron, I have pasted the 2017 NEC 480.6.
This was 480.5 in the 2014 NEC.
Yep, "prime mover" refers to the engine/turbine turning an alternator/generator, or "the first thing that turns" in the system .
480.6 permits batteries that provide power for starting, ignition, or control of a prime mover (Generator) to not have overcurrent protection for the conductors between the batteries and the starting equipment of the generator.
Chris
I'm not surprised.It is a bit surprising that the code does not require it. ...
There is s safety reason behind not having a protective device for conductors intended for starters or to initiate operation of prime movers, controls et al.
Starters only run in a few seconds. The power burst needed are also unstable especially when a few attempts failed where drop in battery voltage leads to rise in Amps.
I would hate to see an emergency power cells, battery banks unable to start a prime mover that would cause a life and death situation in an ICU (hospital) caused by a blown 50 cent fuse.
This is a territory of ASME and I'm sure they did a lot of thinking to come up with the idea.
