jerryb52
- Lake Worth, Florida
I was told there is a code article that prohibits the use of stranded wire wrapped around a ground screw. Is this so ??? And what would that article be ???
The way I do it there are no loose strands. I always come back an inch or so from the end of the wire and strip a section, pulling the insulation over the end. I was taught this long ago.
This has always been acceptable in the past, if done correctly.
I was gigged for it today and was told that it was in the code book since "99"... Was told that StayCons had to be used with stranded...
Just want to do it right.... Thanks, Jerry
