stew
- federal way,washington
I am close to doing an outdoor panel replacement which will require a shutdown so I wanted to get all my ducks lined up to prevent surprizes. Upon inspection of this bottom entry there is a 2 inch what measures to be a rigid conduit on the line side. There is what looks like a 2 inch emt fitting attached to the pipe. It is a sleeve type just like an emt with one set screw. Something I havent ever seen. this existing install was installed in around 72 or so and is close to salt water and has rusted out the panel. Anyone ever seen this type of fitting or is this an emt fitting perhaps that someone has forced onto the end of a 2 inch rigid?
