On a job recently, the drywall taper told me that his vacuum shocked him every time he turned it off. I was intrigued and took it apart. After a bit of poking around, I found that the ground wire was draped across the lead closest to the motor winding, but its casing was intact.
After thinking about it a bit, I decided that the field collapse from the motor must have been strong enough to throw its impedance through the ground's jacket and send a bit of the collapsing amperage at him.
I kind of laughed to myself that the wire had jostled itself to that spot. But I also marvelled a bit at the power of a collapsing motor field.
