We have a very large 6000hp motor that we took out of service recently to do a routine inspection/maintance on the motor and gearbox. The company that was going through the motor noticed that there was several locations on the motor especially the bearings that were pitted which he is claiming is a result of stray current. Someone here has said that in the past the shaft of this motor was damaged due to stray arcing current as well.
My qustion is weather or not this stray is known to cause this type of damge in motors, or if it is just a red herring that someone is throwing out there? Can anything be done to prevent this damage if it is indeed from stray current such as grounding or something else?
