Bill Cary
New member
- New Jersey
Team, first time on, and I can't tell you how thankful I am I found this forum!!! All I've read indicates this is where I need to solve my problem.
Just completed a fiberglass pool installation, all electrical inspections have passed without issue, however, Stray Voltage is resident (5-6 volts directly in the pool water) the only metal (which is properly bounded) is the pool's hand rail) there's no other bounding grid system around the pools perimeter..it's simply not required by code, nor were we aware of any stray voltage condition prior to the install. Research has suggested installing a grid system 3 feet from the perimeter of the water, the problem.....all masonery work is completed. Can I install grounding cable and rods around the perimeter of the concrete? to eliminate the issue. The concrete spands anywhere from 4 to 16 feet around the pool?
