Stray Voltage in Pool
You need to go back and watch “ MikeHolt.com/Pools” and Neutral to Earth Voltage.
Pool Equipotential Bonding creates an electrical common area where all conductive parts of the pool and surrounding area have the same electrical potential. That includes the water.
You never even stated with your light problem, if the light circuit is even on a GFCI.
The NEC has changed over 30 years and you want to bring this pool up to current standards download the document that accompanies the pool video “ How to Verify the Electrical System of a Pool is Safe in Accordance With the NEC “
If you get involved be careful of the legal liabilities.
Alight thanks for the suggestion. Maybe I'll recommend that first as it should be done anyway. But yea I agree I think they have to face facts and consider rehabbing the pool deck sooner rather than later. You're referring to a perma-cast device correct?
Perma-Cast PB2008
I'd be very interested to learn and understand more on this matter. Like HOW??
Anything that increases current on the neutral will cause higher NEV because of basic voltage drop. Then there is failed connections that directly cause rise in voltage.
