WestCascadesElec
- Vancouver, Canada
My accountant called me to help troubleshoot a issue he is having at his townhouse. Here is what happened so far, coax cable burnt clean off of his receiver box at the main tv and in the master bedroom the ground wire in tv power supply cord heated up only on the ground wire and melted it a little bit. So now there is a spiral all along the cord from plug to tv. His range was off and randomly started smoking so it was shut off at the breaker. I come over to try and start looking into this, what I have found so far is there is a voltage difference of approx 10-12 volts between ground and neutral at every receptacle and also on the panel mains. Between a grounded outlet and coax ground in a room there is the same voltage difference. I go to the garage and open the panel and also the tel/cable supply panel, disconnect all coax lines running up the rooms and measure them, 0 volts difference. I measure the coax line leaving the townhouse to the main ground in the panel and same voltage difference of 10-12 volts. I've never encountered this before but only heard of guys trying to troubleshoot it. Where would be the best place to begin looking at it?
Thanks for any insight
Forgot to mention, tightened all neutral and ground connections in the panel. Some were quite loose
