Paul Allen
Electrical Contractor
- Middleburg Florida
- Electrical Contractor
I thank you for your responses, to add to the situation, and clarify it somewhat, i should add that this pool is a concrete pool, but has a rubber liner in it and has saltwater in it which to me maginifys the problem by creating a potential difference from the water to the equipotential grid.and a good conductor inside the pool. The only place i can see that the water in the pool and the surrounding area can be connected electrically is thru the hand rail that enters the water and the light fixture in the pool. (All of the other fittings in the pool appear to be non-metallic) I Have completely disconnected all power to the home to eliminiate the possibility of something in the home causing the problem. The only way the current flow is interrupted is by disconnecting the grid from the equipment grounding conductor to the home, which in this case is the pool motor housing and timer housing, It still seems to me that the voltage is in the ground around the pool and finding its way back to the source on the residential transformer neutral.
It was suggested that the stray voltage could be flowing from the neutral on the homes transformer network to the pool grid and flowing toward the high voltage distrbution lines neutral instead of the other way around as I think it is. If this is the case, wouldn't the greatest voltage be present between the water and the earth right around the pool? As measured, the farther I get away from the pool toward the High voltage powerlines the voltage increases,and measuring voltage from the pool in the oppisate direction the voltage decreases to near 0 V
My question is, would a ronk blocker be applicable to this situation? and could it be installed on a residential pad mount utility transformer? it sounds like it is designed for overhead installations only.. Not being familiar with this product, it sounds as if it works like a ground impedance, installed between the primary and secondary neutral on the transformer. Could this be installed somewhere on the secondary side and still comply with the NEC? Sorry for being so long with this post, thanks for everyone's input
Paul Allen
Florida Master Electrician
Paul Allen
