Hi,I came across a problem today a 120/240 200A service,which has 14 volts AC from the ground,ie my meter lead stuck in the ground to the ground rod.I turned off the main breaker and still had this voltage.I went to an other service panel off the transformer on the pole via triplex(the first service runs under ground in pvc pipe to a dirt vault then off to 3 other meter bases in pvc) , back to the triplex this service also had 14 volts to the ground(meter base can), So I went to the ground running up the pole to the transformer it also had 14V to the ground.up this pole is a 3 old 3 phase set up, now only using 1 of the trnsformers but a lot of the old 3 phase system is still up including transformers.
Any Ideas ? Anything I should check before calling power company
Thanks for your time Mike
