bro15381
- Wauseon, Ohio
Wonder if any of you out there has ever experianced this.... I have some automatic waterers at home for the horses. One of them is getting 5 volts. The horses refuse to drink out of it. I have installed four ground rods and drilled and tapped the stainless waterer bowl and still read 5 volts to ground. I even took a piece of wire #12 and stripped the end of it, put it under the 10/32 screw grounding the bowl and put it in the water. Still 5 volts to ground when testing between the ground screw and the other end of the meter in the water. Shut the power off to the water heater (located under the bowl) and still read 5 volts. I am using plastic pipe from the well to the Nelson waterer. The other waterer is fine....???
