electricalperson
- massachusetts
has anyone here ever came across a stray voltage problem? will you be willing to share with us what you found? what test methods did you use and what you did to fix it?
No but anyone with issues within 100 miles of wsahington DC (maybe further) I am willing to travel and work for free. ....
No but anyone with issues within 100 miles of Washington DC (maybe further) I am willing to travel and work for free.
What types of issue are you having?
You are just measuring the voltage drop on the utilty primary and secondary nuetral conductors when you take this measurement. The bigger the load and the longer the neutral conductor, the more drop you will see.
You are understanding it correctly, but I have no idea of what the upper limit of a normal votlage drop would be. If this system has a primary neutral, I could see the votlage drop being a lot more than a few volts.
The power company pretty much does that.
They can pull a meter, replace it with a plug in load bank that tests for voltage drop line to line and line to neutral, I imagine they are looking mostly for a major difference between one reading and the other.
BTW sometimes power companies are the fastest way to do the testing, I figured out I had a voltage problem at my own house, I had left my 87 on record overnight and found one leg to neutral was going up and down from about 90 to 140 volts. I left a voice mail with the POCO at about 6AM and headed off to work, by 10 AM they called me and said they tested and where sending a line truck out. By noon it was fixed all no charge.
hopefully i come across a major stray voltage problem in my career someday i would love to see this.
Lets locate an issue in NJ, we can team up, or if your near Boston I'd consider a trip to see the family as part of the job.
