brightidea
- Ontario Canada
What's the best trouble shooting practice when confronted with streetlights not working?
When approaching a streetlight with an apparent fault how is it confirmed with the power turned off?
How about an apparent fault on a circuit with power present?
example: 120vac streetlight is inoperable, the connections at the handwell show 120volts present, tested with a digital multimeter.
If 120vac is there, does that mean the street light is operational or not?
How do you confirm that the neutral is working?
Must a load test be done to ensure that the circuit is ok?
I am encountering several issues when it comes to underground streetlighting feeders.
could we engage in a discussion on this topic?
thanks,
brightidea
thanks,
brightidea
