peter d
- New England
Why are they required?
mdshunk said:For stress relief.
stickboy1375 said:what are they?
Just think of it like a plumbing "reducer" fitting. You have electrical energy coming down the pipe (wire) and if you just cut off the insulation, it will tend to blast right out the end. You need a stress cone to bring it to a subtle stop. Consider that the first layer of the insulation on the high voltage cable is semiconducting, so you need fitting on the end (the stress cone) that mimmics the conductor's insulation. Layer of semi-con, and a layer of dielectric. If the high voltage cable was just insulated with dielectric, that would have to be some pretty darned good insulation. They layer it first with semicon to limit the amount of actual energy that the outer insulation is exposed to. Same goes for the terminal end, thus you use a stress cone. It keeps the shield sufficiently far away from the conductor. The high voltage guys might have some other stuff to add, but that's about it in a simple nutshell.peter d said:That's what I don't get. Where does this "stress" come from? What causes it?
