String Testing
What would be the easiest and most reasonable string tester. Looking for something that will store all readings IV curve and print out a report. Cost is always an issue however productivity is a must.
Sent from my iPhone using Tapatalk Pro
Coppersmith
Tampa, FL, USA
Electrical Contractor
My cats like testing string. They are free to good home if you pay shipping. They don't store any readings, but they will sit in your lap if you are reading. They tend to push your book if you don't pet them.
pv_n00b
CA, USA
Not a lot of choices out there. Seaward and Solmetric on the small end of the scale. There are testers that will let you test whole combiner boxes at a time and those are in the $30,000 range. Needed on utility scale projects.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
Unfortunately setups which can run an I-V curve on single cells or panels are in a different ballpark from those which can run the same curve on a full string, because of the much higher power dissipation required of the test load when working with a full string. Also voltages can exceed 1000V.
