It`s been about a month or so since I cashed in CU.It was $3.05/lb #1 and $2.95/lb #2 ,$1.75/lb unstripped #3.
Back around 1975 I worked with a guy that made a jig to strip wire,It was a vee block of 2 X 6 with a utility knife in the bottom of the jig and a roller above it centered in the jig he used 2 sash weights to apply pressure.All you did was slide the wire in the jig release the weighted roller and pull it through,pull off the insulation and it was done.He did #2 and up with this jig worked like a charm.But that was in 1975 and CU was #1.00/lb but the min. wage was like $1.75/hr so do the math in todays prices and wages.
