bjp_ne_elec
- Southern NH
Always wondering what others do when they have to strip back UF cable. and what tool(s)/tricks you might use.
Thanks
Brett
Thanks
Brett
bobbyho said:The grounding wire usually runs down the middle. I take a razor knife,slice into the center of the cable, drag it along the ground (towards the center of the cable),pull out the bare cable, Then the two insulated wires I use my stripper (10awg) put a slight cut and strip the whole outer insulation off each conductor. Sounds like alot but it goes real fast. BUT I do hate the stuff too.
bobbyho said:... I take a razor knife,slice into the center of the cable, drag it along the ground (towards the center of the cable),pull out the bare cable [grounding conductor]...
infinity said:I always use a simple UF cable stripper. No more nicks in the wire and taping. The tool not only is fast it eliminates all of the problems associated with using a knife. The particular stripper that I have is about 15 years old. Don't know if they even make it anymore.
I used to strip NM with a knife too. Then one day (a long time ago) I bought one of the little $1 "gadgets" to strip NM. Since then that's all that I've used. That and my dikes (hand tool, not my hired help). Strip it, pull the outer covering (and paper) back and clip it off. It's quick.j_erickson said:I never have a problem stripping UF with my knife. Of course, I use the knife for stripping romex as well. Been doing it that way since I was 12. But I know from an old poll, I'm definitely in the minority. Most guys use some sort of cable stripper.
LarryFine said:I have used every method that's been described here, including the Zip-stripper.........Now, for 12-2 and 14-2, I use the Klein NM stripper pictured here.
