Structured cabling systems
alaskan JW
Anchorage,Ak
What type of cabling systems do you guys use in homes. I have been doing some research and all I can really find is levinton. Have a customer that wants audio and video distribution along with phone and cable.
sparkyjim
Dallas, TX
If you're new to distributed audio/video, you probably ought to look at Niles ZR systems. They have some very nice and relatively simple systems. Stay away from the IP addressable until you've had a chance to sit through some workshops. If you have any ?'s, ask.
brantmacga
Señor Member
Georgia
Former Child
mdshunk said:
I use a piece of plywood.
I'm assuming that's in the basement?
I would do that if it were an option, but homes aren't built w/ basements here, and I've only worked on maybe two homes that had some type of mechanical area that could be done.
Anyway, that said, I've always used a flush enclosure.
I've used leviton w/ no problems, but I've started using products from Suttle (price). The link will take you to their residential products page. If you create a username and password, the prices will be on there; its less expensive than leviton, and I've found those 8-port patches to be useful compared to leviton's 6-port. The prices they show are about 5% higher than I pay at the supply house, so that may give you an idea of what you're paying.
alaskan JW
Anchorage,Ak
thanks for the link
e57
Don't mind enclosures - I HATE THE PARTS THEY COME WITH!!!!
Might I suggest reqular 110 and 66 blocks for phones and data, and regular CATV splitters in an enclure or your choice....
And a quick light read:
http://www.markhellerelectric.com/phoneclass.pdf
AV stuff - unless you like trouble it is best avoided for high end stuff - or get used to doing an enourmous amount of reseach....
alaskan JW
Anchorage,Ak
Thanks for the link but I dont know if that is a light read :wink:
sparkyjim
Dallas, TX
We use the Open House Enclosures, 36" and usually use two or three. I won't use any of their other products. I thought you were wanting info on A/V; should have read more closely. A structured cabling system may be the backbone for a distributed audio/video system; you usually can't fit the required equipment in those enclosures. Netstreams is a good one if Niles isn't big enough. Most structured cables have 2-catv and 2-rg6. rg6 is only good for the "line" side of the equipment.
brantmacga
Señor Member
Georgia
Former Child
suttle has 66 blocks that snap into their enclosure.
e57
Still like off the shelf plain ol' vanilla stock... No special order/waiting... Just a self drilling screw to put a regular bracket in most any enclosure - even a good sized J-box....
On a few commercial installs I used 6X6 gutter with 110's as intermediates and 2" conduits back out relocate com rooms across an exposed cieling. Then into a 20X48X6 tapped for 19" hinged patch panels and cable managment - the inner lip of the boxes I used was a perfect fit.
