strut-type channel raceways
finhead
Good Morning
Can someone tell me why 384.22 specifies using the outside diameter of a conductor to determine strut fill? Also, T384.22 is titled "Channel Size and Inside Diameter Area."
As I read the code, inside diameter has nothing to do with calculating conductor fill.
Thank you
Brian Dolan
Re: strut-type channel raceways
Maybe it is a mistake and is referring to the cross sectional area of the inside of the strut and not the ID?
My guess would be someone copied this from a section having to do with conduit and forgot to change the terminology.
[ August 18, 2005, 11:51 AM: Message edited by: petersonra ]
Aren't all wire fill tables based on the outside diameter dimensions of the conductors? Why should this be any different for strut type channel raceways?
OD of wire/cable and ID of raceway.
