mstrlucky74
- NJ
If you had to provide tele/data stub-up but there was a window in the vertical location what would you do? Would you have to come up from floor below and to nearest column? Could you run conduit( and it has to be EMT) horizontal in the wall a bit then stub up when you clear window? Thanks.
Actually just caught this detail 5 where it says accessible panel with camlocks, locate new power and tele/data but that location seems to be on the other wall to the right of the outlets? :?
