starbright28
- Minnesota
i found through studying and taking the test so much that I have some key areas that I don't know a lot about. my list is as follows:
If anyone would like to contribute - please reply!
That hard one fore me is finding a good one line diagram to learn, disect, etc and figure out.
thanks in advance!
- va & kva calculations
- Minimum size conductor for a group of motors
- maximum load on any cord and plug connect utilization equipment when connected to branch circuit
- ampacity of wire with ambient air temperature
- conduit change outside ambient air temperature. say goes from summer 70 to winter -20. do you just take the value in teh chart and that is it?
- one line diagrams - an explanation on them. like if you pushed down a pushbutton, what will the motor do, run jog, not work, etc.?
- how much to add to feeder (continuous load)
- range calculations - especially ones that are mixed kw ratings and how to work the problem.
thanks in advance!
