Coppersmith
- Tampa, FL, USA
- Electrical Contractor
Summary: I need an opinion here. This takes place in Florida. The POCO's drop to a house had an fault. The fault destroyed the HO's stove, fridge, a lamp, and a surge protector. The POCO is refusing to reimburse the HO because they didn't buy house wiring protection the POCO billed monthly for. There is no doubt in my mind that this is the POCO's fault. Can they get away with not reimbursing the HO? Is there any recourse?
The rest of the story: POCO's drop runs by a tree that had been rubbing the conductors. POCO installed a plastic cover over the conductor to protect it. The drop failed anyway. POCO replaced the drop. I only have the HO's description of what happened next. He spoke with the lineman doing the repair. Either the neutral failed or a hot contacted the neutral. I don't know which happened.
The fault caused some lighting in the home to go very bright. A fan near the HO slowed down. One light bulb burned up. Both the stove and fridge stopped working and had to be replaced. A kitchen GFCI failed and when I replaced it the back had blown off. The surge protector mounted on the outside of the outdoor panel literally exploded (it had a big hole in one side) leaving black soot all over the siding.
So your opinions please. Is this a situation where the POCO should be reimbursing the HO even though the HO didn't buy an optional indoor wire protection plan? If the POCO continues to refuse to reimburse, can the HO complain to a public service commission or similar body? Any other options?
