Okie-dokie! Before I energize a new circuit, or one that's been repaired or modified, I check to see if there is a short circuit by touching one lead of my solenoid-type tester to the hot wire of the circuit in question, and the other lead on the load terminal of a breaker that is on.
I might be misunderstanding what you're saying here, Larry. Wouldn't that just make sure the new/repaired/modified circuit isn't shorted to the phase of that one breaker? Does it matter which phase the hot breaker you use to test is on? Just a little lost here.
