We are installing an outdoor disconnect for a 200 A service in a residential home. We will be running 4/0 AL from disconnect to the main panel inside. I have always ran 200 A sub feed cable ( I believe 4/0-4/0-4/0-2/0 AL)
My question is..... why does the “ground” running from disconnect to panel need to be sized differently than our “earth grounds” (#6 Cu)??
Can you site the NEC on this please? My helper asked me why and I did not have a definitive answer for him. I always assumed we sized equipment grounds on the size of the feeder cable but is the fourth wire in a sub feed an equipment ground? I am confused on this subject.
Thank you in advance.
