karn
- United States
- Electrician
I think all feeders and sub feeds for panels need bonding bushings, but what if i use a chase nipple to connect the two panels or panel to gutter, I suppose you could still get the bonding bushings on one side but if they are connected using a rigid coupling as a raceway then what? I'm also not sure rigid couplings are listed as raceways or if it would be a legit install but theoretically a close nipple could be cut to fit inside the coupling
