why do we run the greeb wire.
Are you asking why we use an EGC instead of bonding the neutral?why do we run the green wire.
what good does the green wire do in a sub feed if i use metal conduit from main panel to sub panel ?
It's not required if you're using metal conduit with proper bonding methods.what good does the green wire do in a sub feed if i use metal conduit from main panel to sub panel ?
Gives some folks who don't trust the integrity of the conduit a warm fuzzy feeling to see the conductor.what good does the green wire do in a sub feed if i use metal conduit from main panel to sub panel ?
Nothing wrong in having both though. Seen too many conduits used as the egc damaged and separated, and nobody knows about it until someone gets shocked or electrocuted. If the damage is severe enough to break the ground wire, then most likely there will be a short amongst the other wires, causing the ocp to trip.The equipment grounding conductor can be either metal conduit or a conductor. Some feel that the green wire , equipment grounding conductor, has a less chance of human error (not tightening the couplings etc,) than the conduit. In fact, the conduit is a better conductor than the wire style ground. The conduit has less impedance.
See post #16Gives some folks who don't trust the integrity of the conduit a warm fuzzy feeling to see the conductor.
No!bonding sub feed. if i run metal conduit fron main panle to sub panle do i bond the neutral to the sub panle ?
