jwelectric
- North Carolina
If this tub was inside and not outside and the NM cable was supplying nothing but the tub then I would look at the breaker as nothing more than a disconnect for the tub.
If this tub is located outside then the issue of the breaker being a disconnect would be mute as any cable would then be a violation as the EGC would be required to be insulated.
