I have a sub panel that needed to be replaced. It was feed with a three wire system. Wire will not budge to try to pull in a fouth wire. No ground rods driven for sub panel. bonding jumper installed in sub panel. How would you proced to replace panel. Main panel in attached garage feeds sub panel in basement through slab.
I replaced panel and right now it is a three wire sytem with bonding jumper installed. Should I drive ground rods and remove bonding jumper and leave it at that? Or leave it how it was? I always do 4 wire systems so I am at a loss.
