GerryC
- West Islip, NY 11795
- Retired Journeyman Electrician A division Local #3 NYC
Hay Guys I have another question regarding a Sub-panel in a Co-Op Unit. The main service equipment is in the basement with a separate main C/B to my Unit. The Main lugs on the Unit sub-panel are used to feed another sub panel (laundry unit 30 amp 2-pole). In a larger panel I would put a C/B to the next Sub-panel but this panel only holds 3 Tandem C/B 6 circuits which is ok. If my thinking is correct even if the feed to the Unit sub-panel is the same size as the feed to the laundry sub-panel (the one tapped off the main lugs) this illegal, can any one confirm my suspicion.
