- Licensed Electrician
I'm a bit surprised that you would ask. Are you assuming that breakers are now not intended has a manual emergency shut off? Really? If so by what means do you suggest that power be disconnected if there is a need to so in a hurry? Take a pair of linemans pliers and cut the wire? According to the UL489 tests breskers are perfectly capable of the task and come back to do it hundreds of times.
If there were any electrical emergency such that could hurt or kill someone or an arcing fault that is not of a great enough magnetude to trip a breaker or another event that may result in a fire any bright ideas? With all the panels as you say are behind locked doors and all the panel doors are locked, yes, if that is normslly the case then there is an issue. So what you are saying is trying to disconnect a main breaker shouldn't even be considered then.
Wonderful.
Like or not we have made electricity one of the safest forms of energy available and also one of the most important which adds up to the majority of breakers located behind locked doors.
Most every electrical shut off is designed to be part of stopping a mechanical system, shutting of the electricity is a means to an end, not an end to itself. The only thing I can think of off the top of my head where there is a quick way to turn off a main is a shunt trip for the fire department on a commercial building and those are locked up to max, not even the building owner has a key.
