Sub panel wiring
ron kesti
New User
retired
0
My son installed a sub pan next to his main panel he installed a generator with an interlock system he did not have enough room in main panel so he removed two 30 amp breakers to the sub panel he installed a 60 amp breaker in main panel to power sub panel and a 30 amp breaker in main panel for the generator. He ran two 6 Ga hot wires from 60 amp breaker to sub panel a 6 Ga from neutral bar in main panel to neutral bar in sub panel and a 6 Ga ground from main panel ground bar to sub panel ground bar. (when he moved the two 30 amp breakers to sub panel he ran the hot wires to the breakers but left the neutral and ground wires in main panel) is this OK.
No it is not okay to do that
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
