I would like opinions on the following install?
I installed an overhead temporary pole at a residential job site.
The raceway above the meter socket is Sch40 PVC.
I failed inspection because the riser was not either metallic or Sch80 PVC.( reason: subject to physical damage)
The meter,which is plastic, and more succeptable due to the height, would be the first weak link if damage occurred.
I've never been called out on this.
Can anyone give me an NEC definition for " subject to physical damage"
Thanks
Thanks
