ESolar
- Eureka, CA Humboldt County
- Electrician/Contractor
I was tripping AFCIs. After an investigation, I found that the ground and neutral in my subpanel were reversed (in other words, the ground from the main went to the neutral bar and the neutral from the main went to the ground bar). After reversing them, AFCIs do not trip.
Questions: Was that a real issue (given that the two are tied together at the main)? Should the neutral and ground in the subpanel be tied together like in the main?
