AZsparky
- Scottsdale, AZ
Below is from a client looking for sizing a new garage subpanel. Residential application and of course he wants the least expensive subpanel to meet his needs. I think a 12 space 100 amp subpanel fed via 100/2 with 1/0 AL SER cable. Or does anyone think a 70/2 breaker with #2 AL SER would suffice since probably only the A/C and the misting pump would be fairly constant loads? Any input?
From the client:
Here is the load requirements and the outlets the best that I can estimate.
1. Air compressor 15 amp draw at 110 or 7.5 amp 240 volts (inside garage
wall)
2. Welder running 20 amp draw at 110 (< 6 feet from panel Inside wall) 3. Air conditioner 15 amp draw at 230 (<3 feet from panel inside wall) 4. Misting pump 15 amp draw at 110 (outside wall <5 feet from panel) 5. one spare outlets inside garage 20 amp for (<6 feet from panel for band saw, grinder, drill press etc.) 6. One spare outlet outside wall 20 amp
All single phase.
From the client:
wall)
All single phase.
