View attachment 85steve66 said:Smart$:
No more clues or hints. Not even a dead-giveaway. Please just tell us why only two answers are correct:smile:
Steve
In the diagram, current is flowing from B to A, therefore I_BA and -I_AB are positive.For current, the notation defines the direction of flow of current when the current is considered to be positive. For example, Iab would mean the current is flowing from point a to point b. Iab = -Iba.
In the diagram, voltage is positive when measured A with repect to B, therefore V_AB and -V_BA are positive.For voltage, the double subscript denotes the nodes of the circuit between which voltage exists. As stated earlier, the convention is that the first subscript denotes the voltage of that node with respect to the node identified by the second subscript. Vab would be the voltage at node a with respect to voltage at node b, and that Vab is positive. Vab = Vba @ 180 deg = -Vab
There are no -V_BA's in the equations provided. Equations of 5 through 8 are eliminated simply because the notation V_BA is not positive, even though the equations of 5 and 8 would be mathematically correct. Equations 1 and 4 would yield a negative value for R, which we all know is not possible, and also do not meet the criteria for current notation.
Of course the above is only considering the resistor portion of the circuit. If the battery portion of the circuit was under consideration, the equations of 1 and 4 would be correct.
