Originally posted by adavey:
Is a voltage measuremnt from line to ground rod ok to do ???? Assuming it's a good ground I should get 120V.
Yes, but that won't tell you anything.More specifically, can I measure ground rod resistance when installed ??????
Read 250.50. All electrodes are created equal in the eyes of the NEC. They all must be used.Originally posted by adavey:
Is the ground rod a secondary grounding element to the ground system (water main being primary) ?
We recently installed a ground grid for a new 34.5kV substation which was on a piece of ground that once was an old mine in New Jersey (filled in with sand). We drove sectional ground rods down 50' at multiple locations and still barely got below 5 ohms. My design called for 1 or less. Installed a CCE, problem solved.If you have only a CCE, you're done. It's not going anywhere.
