Hello. Replaced a pump today.
The name plate was pretty messed up but didb notice it said 0.3 hp 115v 9.7 amps
I looked at the chart and the .5 hp was closer to that amperage
At the plumbing supply house the home owner and I picked up a zoeller 1/2 hp at 9.8 amps which matches the motor chart.
Still scratching my head on this I located the .3 hp motor on line
http://www.supplyhouse.com/Zoeller-...-115-V-03-HP?gclid=CPbH_47R38sCFdhahgodSWAIhA
Check specs on drop down. this is the motor I took out .3 hp at 9.7amps
Not the 7.2 amps like chart says for .3 hp
Why you think?
And kinda messes up using chart hp and ampacity theory for replacing motors
Thank you
Why you think?
Thank you
